Message 1 of 8
Wholehome 5ghz
Is there a way to disable 5ghz on the wholehome discs? Its playing havoc with my Dyson fans and my Ring Doorbell systems?
7 REPLIES 7
Message 2 of 8
Re: Wholehome 5ghz
Hi,
There is not currently a way to disable the 5ghz band that I know of.
Have you tried changing the 5ghz channel to see if that has any effect?
Mike.
Message 3 of 8
Re: Wholehome 5ghz
Hi Mark - thanks for taking the time to reply. Yes I tried that and set the 2.4 to chan 6 (my Sonos is on 1) and pushing the 5ghz out to the highest chan (can't remember what that was) and it does seem to be working. The Dyson is a bit hit and miss still.
Cheers
Message 4 of 8
Re: Wholehome 5ghz
And the Ring is fairly stable.......at the moment 👍
Newbie
Message 5 of 8
Re: Wholehome 5ghz
I realise this is a VERY old thread - but just in case, can I ask how you manage to set up the fan is the first place ?  I recently switched to Whole Home and when I try to go through setup on the Dyson Link app, it refuses to accept that my iPhone is connected to my home network although it clearly is.   I'm assuming it is because the phone connects at 5Ghz and the app simply will not allow it?
Recognised Expert
Message 6 of 8
Re: Wholehome 5ghz
BT Whole Home Wi-Fi ( White Discs) send both 5GHz and 2.4GHz i.e. AC2600 Dual-Band wireless technology. so devices should have the option to join the network using either. However some 2.4GHz device can have a problem setting up if both are visible.
If you are having a problem setting up a 2.4GHz you can stop 5GHz for a short time using the WEB tool, so you can target your setup.
Newbie
Message 7 of 8
Re: Wholehome 5ghz
@Injar02
Thanks for that helpful info.  I did look in the web interface but either I missed the option to temporarily  stop the 5Ghz band or that option is very well hidden.  I will have another look later - or is "the WEB tool" something different?
I have found that the Guest WiFi is recognised by the app as a valid network (probably 2.4GHz only?) so I could set it up on that but it would mean swapping WiFi networks every time I wanted to access the fan.
Recognised Expert
Message 8 of 8
Re: Wholehome 5ghz
Hi the guest network is also dual band and the Web tool is the same as web GUi. It looks like the Web but is from the firmware on the Whole Home.
