Joshporritt
Newbie
Message 1 of 2
Wholehome WiFi App
I have my wholehome WiFi attached via Ethernet to my BTHH5. On the wholehome app, it shows the other devices that are connected to the BTHH5 via Ethernet, and always displays them offline. Will forgetting them from the app a) stop them working and/or b) mean they’ll end up back again on the app anyway?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Wholehome WiFi App
Hi @Joshporritt  Welcome to the forum and thanks for posting.
Check out the BT Whole Home Wi-Fi help page and if you can't find the answer you can call or drop the product helpdesk an email and they will be happy to help.
Cheers
John
