Message 1 of 3
Why is my by home hub flashing orange?
2 REPLIES 2
Message 2 of 3
Re: Why is my by home hub flashing orange?
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/what-do-the-lights-on-my-bt-hub-...
If this has been more than a few minutes, you probably have a fault , so it’s time to contact BT about it , it could  be individual to you or possibly you and others are affected by a common issue , either way contacting BT will get the appropriate action implemented
Message 3 of 3
Just restart it, or turn it off and on again.
