clivec
Newbie
Message 1 of 2
Wi-Fi Home hotspot 500
My Hotspot 500 wireless light is not on, which suggests wi-fi is disabled. Any ideas how I can enable it.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Wi-Fi Home hotspot 500
There's a web console for administering the Hotspot.  Try typing http://bt-wifi-home-hotspot.home into a web browser and see if you get to it.  If not, try  http://192.168.1.64 then http://192.168.1.65 and so on until you find it.
Eventually, you should get to a web page asking you for a password.  It's the bottom one on the pull-out tab on the back of the hotspot.
Select Advanced from the top menu, then Wireless Settings on the left menu.  Check that Enable wireless network/SSID 1 is ticked.
