My neighbour has Virgin wi fi. Every time she turns her TV on or off it resets my Hub. Anyone else have the same problem or even an answer?
Welcome to this user forum.
Is your home hub or phone wiring, on the opposite side of the wall to her TV?
If it is, then has the TV is turned on and off, it may be causing the home hub to disconnect.
Do the lights on the home hub change colour when you lose your connection?
Is it just that your wifi disconnects but things connected to the home hub using an Ethernet cable, are not affected?
She lives in the flat below me. Her lounge is below the Hub. The Hubs light go to orange whenever I check rather than just wait for it to reset. I just had a long conversation on line with BT help and the person in question wanted to send out an engineer. I stated it is interference3 from my neighbours remote but she seemed fixated on a line problem not an interference problem.
Then its probably just electrical interference causing the home hub to drop its connection. You could try moving the home hub to a different part of the room, to see if it helps.
Also make sure the home hub is plugged into your master socket, and any extension wiring is disconnected, as that could be picking up the interference.
Plasma TV sets normally cause the most interference owing to their much higher power consumption.
Its unlikely to be her Virgin hub, as that would normally be on all of the time.
Out of curiosity have you asked if her hub drops connection when she switches to on/off. Maybe electrical fault causing interference. What about other neighbours?
