Just fitted Ring doorbells and external security lights/cameras. Struggling with WiFi strength to run some of the new items. Also using Ring Chime Pros which are supposed to boost WIFi. Not able to relocate router and get adequate Wi-Fi in house.
Would complete WiFi disc solve the issue? Appreciate “guarantees” signal in house, but does this include external products such as cameras / doorbells etc?
Are you sure the problem is with the Wi-Fi strength?
If you're using a BT router try turning off Smart Setup (What is Smart Setup on the BT Hub? How can I turn it on and off? | BT Help) and temporarily turning off the 5 GHz carrier
