Message 1 of 12
Wi-fi Calling BT Set up help - Not mobile phone set up.
Hi I see others have asked similar problems, but my issue appers to be different, I can only assume is related to my router settings.
I have a Samsung Galaxy Note 8 on Vodafone and have wi-fi calling enabled. (I have been through thr phone settings to enable).
When I visit other people's houses, the wi-fi calling symbol appears on my notification bar to say it is available. However when at home this never appears.
It would appear therefore that the problem lies with my broadband/router, rather than my phone. I have logged into my Smart Hub 2 Manager and see that there is an icon with a telephone symbol, but it is greyed out and says 'not configured'.  How do I enable this please and I wonder if this is the problem?
11 REPLIES 11
Message 2 of 12
Re: Wi-fi Calling BT Set up help - Not mobile phone set up.
That icon has nothing to do with WiFi calling. There are no configuration settings you can make on the hub regarding WiFi calling.
Message 3 of 12
Thanks for the quick reply, but I'm afraid you might be mistaken.
I am not referring to the normal wi-fi symbol, obviously all that does is show that I am connected to a wi-fi network.
I am referring to a similar wi-fi symbol, which appears in addition to the usual symbol, but with a small telephone symbol positioned above it which indicates  that wi-fi calling is available.
This symbol appears when I visit my Mums house, she is also on BT Broadband. I've also been away for the past few days at a holiday accommodation and the symbol appeared there too. But not at home.
The question is how come it is available on her broadband but not mines.
Message 4 of 12
I am not mistaken.
I have no idea why it doesn't work with your hub but does with your mum's, but I can assure you there are no settings in the hub to enable WiFi calling.
Message 5 of 12
Thanks, so why is they grey telephone icon on my hub settings greyed out?
I don't wish to be rude, but are you a BT technical expert or a keen enthusiast?
I'm looking for a definitive BT employee technical answer or advice from someone who may have experienced the same problem.
Message 6 of 12
See if web protect is enabled in your MyBT
Message 7 of 12
the phone symbol in hub will change to blue when you have digital voice and using hub as dect base - as mine does   nothing to do with wifi calling as posted by @licquorice
Message 8 of 12
Because you don't have digital voice
A customer the same as you, in case you hadn't noticed this is a customer to customer self help forum
Then keep looking. However, the answer will be the same that I gave!
Message 9 of 12
Hi
Just a thought. Do you have any mobile signal  at home? Even a little bit? Reading through BT’s WiFi Calling setup it says that WiFi calling only operates if there’s no mobile signal.  If you’ve got one if those little mobile signal boxes - like me - connected to your broadband that give you a strong 3G signal, I doubt  the WiFi calling will kick in. It doesn’t on mine. I’ve got an iPhone 11 which should be compatible.  I’ll try turning the signal box off sometime tomorrow and see if I get WiFi calling and let you know.  I’m curious too now.... !
Message 10 of 12
Thanks, I think I've come to that conclusion too, it'd be interesting to hear how you get on.
I read somewhere too that wifi calling is only activitated of the mobile signal is poor. I have a very strong Vodafone 4G signal, so that could be why - it seems logical.
