pddco
Message 11 of 12
Re: Wi-fi Calling BT Set up help - Not mobile phone set up.
Well that was interesting.
I switched the box off. Checked  I had no mobile signal. Checked I’d got WiFi Calling enabled. Got  a strong WiFi signal. And yet I couldn’t make a call. No WiFi calling icon or whatever on my phone. So not sure what’s going on there. A bit busy at the moment to have a look and see if I’ve missed a setting somewhere. Though now wondering whether the ‘Web Protect’ option that was suggested earlier may need looking at.
pddco
Message 12 of 12
Hi
Got my WiFi Calling sorted. But only after fitting a replacement SIM. Once that was fitted - it arrived the next day - and activated - took about 15 mins - I put the phone into Airplane mode. That switches off the mobile’s 2/3/4G radio. So now just working on WiFi I could  make a phone call as normal - In other words not using WhatsApp, FaceTime or whatever.
Apart from the mobile signal strength display disappearing, there wasn’t any obvious  sign that I was making a WiFi call. Until that is I swiped down the signal display and it said ‘BT WiFi Call’ next to the WiFi icon.
I switched Airplane mode OFF so the mobile 2/3/4G radio was active. The signal level was about 1 or 2 bars, and I made another ‘normal’ call. Judging by the quality of the call I think it was still doing the WiFi Calling thing.
It would seem that if the WiFi signal is good , and your phone is WiFi calling compatible then it’s all seamless.  The call quality is far better than if you’d only relied on the mobile signal.
