licquorice
Message 11 of 22
Re: R e: Wi-fi dropping and range radically reduced - Hub4
Although there is a school of thought that because of CSMA/CA it is better to use the same channel rather than a partially overlapping one if complete non-overlapping is not possible. I'm not sure that I subscribe to that view, particularly if one signal is being saturated due to streaming.
Keith_Beddoe
Message 12 of 22
The problem is that you cannot see the other multiple sources that use the 2.4GHz allocation, without a spectrum analyser. You can  buy a USB wireless receiver, and suitable software, but its not cheap.
Even on my Asus Netbook, with a wireless card that has a promiscuous mode, I can see wireless routers with hidden SSIDs, that are occupying channels. These do not show up on a normal wireless  adapter. The spectrum is more crowded than people realise.
licquorice
Message 13 of 22
Indeed, I think the only real method of selecting a good channel is trial and error!
Keith_Beddoe
Message 14 of 22
Exactly, and be prepared to move a single channel up or down, to see if it improves performance.
Use Ethernet or powerline adapters as a first choice, for devices that stay in house, keeping wireless just for those roaming devices where performance is not a major issue.
Things like smart TVs, should only be connected via wireless, as an absolute last resort, as they consume vast amount of bandwidth, leaving every other wireless device stuggling.
Gary_C
Message 15 of 22
Ive wondered about this.
Its been many a year since i did sideband radio at uni, but that only covered AM/FM tranmission and was before WiFi at home existed 🙂
Gary_C
Message 16 of 22
yes, of course you are right about overlap, but essentially 1,6 & 11 is a easy way of thinking of it but your diagram is simpler
until someone uses 40mhz and spreads even more 🙂
Keith_Beddoe
Message 17 of 22
Like the Virgin Media Superhubs Smiley Sad
Gary_C
Message 18 of 22
Looking into it, WiFi uses QAM so the spread is due to the FM part of the modulation spreading around the centre carrier frequency ? So will CSMA look for transmissions only at the carrier frequency before transmitting or the whole used spectrum ?
Keith_Beddoe
Message 19 of 22
I would expect it to look at the centre frequency, as modern radio front ends take samples at a specific rate which relates to the centre frequency of the carrier, unlike the old radio receivers that were superhet https://en.wikipedia.org/wiki/Superheterodyne_receiver designs, and had a defined bandwidth.
But its all done by clever mathematics, which I could not start to understand. I was brought up on old radio stuff, using inductors and tuning capacitors Smiley Wink
Anyway, getting a bit off topic now.
Gary_C
Message 20 of 22
Known what you mean. As an instrumentation mechanic originally, all the stuff I worked on used valves not transistors as amps.
so if the carrier sense of CSMA detects the carrier, it might not be able to tell that channel 6 is active when beginning to transmit on channel 7. This seems to be the point some are making in only choosing channels 1,6 &11.
