JennyD76
Message 1 of 15
Wi-fi dropping
For the last two weeks my iPad has been dropping Wi-fi sporadically, this is only solved by turning Wi-fi off and then back on. My non apple phone and laptop are fine. I contacted apple three times now, in the last conversation they informed me that the problem is likely with my router and something about bandwidths? I am not very tech savvy so can I ask if anyone else has this issue or does this sound like a possible source of the issue? iPad and router have been working well together until now.
14 REPLIES 14
B13blues
Message 2 of 15
Re: Wi-fi dropping
You could try turning 5ghz off in your router settings.
B13blues
Message 3 of 15
Re: Wi-fi dropping
While in router settings you could also try turning off smart setup as well.
JennyD76
Message 4 of 15
Re: Wi-fi dropping
Thank you I’ll google how to do that.
B13blues
Message 5 of 15
Re: Wi-fi dropping
Sorry type into address bar  192.168.1.254  and hit enter. That'll put you into router settings. You'll need your password to change settings.
JennyD76
Message 6 of 15
Re: Wi-fi dropping
Many thanks 🙏
B13blues
Message 7 of 15
Re: Wi-fi dropping
No problem fingers crossed it fixes your dropping wifi
JennyD76
Message 8 of 15
Re: Wi-fi dropping
So I gave it a few months and splitting didn’t help it’s still dropping. I’m certain it’s the modem but customer services won’t send a replacement. I just keep getting told to split the signal despite me saying I’ve done it.
now wildly irritated I’m just going to have to buy myself a modem but being clueless I’m not sure what kind. Amazon has a bewildering array all of which I don’t understand. Anyone got any suggestions?
as soon as my contract ends I’m cancelling so something that will work with Sky too
B13blues
Message 9 of 15
Re: Wi-fi dropping
If using HH6 you could go into settings and try changing wireless mode to 2 and then 3 if it is no better. Home - advanced settings - wireless - click on mode 1 and it will give you options to change. You need to click save. Good luck.
Message 10 of 15
Re: Wi-fi dropping
@JennyD76
This modem/router works just fine
The TP-Link TD-W9970 N300 for about £40 or less. Very good value for money, and readily available locally (Argos and others), or Amazon. You can also use it with most ISPs.
Its in use by quite a few forum members.
If you need any help, please ask.
Please read this post https://community.bt.com/t5/Home-setup-Wi-Fi-network/HELP-HH6-blue-light-but-no-internet/m-p/1887178...
