purple_kathryn
Message 1 of 11
Wi-fi stops working on mobile phones although icons shows good signal
I thought it was just my phone but it seems to happen to my mum as well. Router is powered on icon shows strong signal (3 out of 4 bars) . I have a home hub 5 & no other issues
10 REPLIES 10
gg30340
Message 2 of 11
Re: Wi-fi stops working on mobile phones although icons shows good signal
Try a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds. This can often sort out problems.
After doing that make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
purple_kathryn
Message 3 of 11
Thank you for the suggestion. I will give this a go!
imjolly
Message 4 of 11
After the reset I would also split the 2.4/5ghz  networks
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
ipollen
Message 5 of 11
I am experiencing the same problem on my HH5. It received a firmware update at 23:00 28/2/2019 and since then the 5ghz WiFi keeps losing internet access. It has been working fine for many years before this last update.
Ian
gg30340
Message 6 of 11
Ian
Have you done what has been suggested on this thread?
ipollen
Message 7 of 11
I have not performed a hard reset but I have rebooted a couple of times which gets the 5ghz working for a short time before losing internet access again.
gg30340
Message 8 of 11
I would suggest that you try the above especially after a software update.
purple_kathryn
Message 9 of 11
Not yet. I'm working myself up to it (I'm recovering from an op at the minute)
ipollen
Message 10 of 11
WIll do a hard reset when I get home.
