RHJVD22
Message 1 of 2
WiFi Disc Factory Reset
If I factory reset my WiFi disc would I have to connect it to my Smart Hub 2 again with the same procedure as I did out the box?
1 REPLY 1
RHJVD22
Message 2 of 2
Re: WiFi Disc Factory Reset
Answered my own question and yes you do.
