Tedwardo9
Message 1 of 6
WiFi Disc and Smart Hub 2
Hi, this might have been covered in a different post.
My disc has been connected to the hub for a couple weeks but as of yesterday, it doesn't want to connect and it goes between the 'slow flashing blue' and the 'flashing red' lights.
I've tried following the My BT app setup instructions, connecting to the hub via ethernet, and it pairs with the solid blue light, and the disc being recognised on the WiFi network.
As soon as I unplug the ethernet cable, it goes back to the 'slow flashing blue' and the 'flashing red' lights occur again.
I'm out of ideas. Any help with be appreciated. Thanks
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: WiFi Disc and Smart Hub 2
Hi @Tedwardo Sorry that you are experiencing a problem with your wifi disc. Firstly can I confirm that you have the Black Complete Wifi disc?
If you haven't tried already then try a factory reset of both the hub and the disc using the pinhole in the back and follow the set up process again.
Cheers
John
Tedwardo9
Message 3 of 6
Hi @JohnC2  thanks for the reply. Yep it's the black disc, and I've tried resetting the disc but its just doing the same thing, except the right stays red.
NeilO
Moderator
Moderator
Message 4 of 6
@Tedwardo9 thanks for getting back to us, can you try a factory reset on your Smart Hub also and let me know if that helps?
Tedwardo9
Message 5 of 6
@NeilO Excellent, reset the hub and it's fixed the issue. Thanks very muchly!!
NeilO
Moderator
Moderator
Message 6 of 6
@Tedwardo9 great, I'm glad that worked for you Smiley Happy
