Message 1 of 2
WiFi Extender 1200
Hi,
I have the BT Smart Hub Router in our sitting room and works well all over the house, however when I go out to the patio and garden area, the signal drops, but still works. So I have plugged in and paired the 1200 extender which shows up as EXT2- *******. I can connect to it, but should my devices swap automatically to the strongest signal between the extender and the main router as I walk around my property ?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: WiFi Extender 1200
Mine does
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
