CTB1811
Newbie
Message 1 of 2
WiFi Plugs
Hi,
I’m currently having to use the WiFi Plugs as my router is no where near my BY Tv box. I have two tv boxes, one upstairs and one downstairs so I have 4 plugs plugged in. I’ve had nothing but issues with these plugs constantly dropping out saying no WiFi connection.
Anyone know why this may be?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: WiFi Plugs
Hi @CTB1811 what type of wifi plugs are you using?
The recommended way to connect BT TV when you Youview box is in another location from your hub is by using BT Mini connectors these work over your homes electrical wiring and not via wifi.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
