MCG65
Message 1 of 7
WiFi adapter gives poor performance with Home Hub 5
Using Realtek WiFi adapter with Windows 10 64-bit. Worked very well with a Home Hub 4, giving 7 Mbps download speed, but performance dropped off drastically with a Home Hub 5, download speed dropping to 1.5 Mbps.
A different wifi equipped machine works well with the same Home Hub 5, which is baffling.
What settings can I adjust on the Home Hub 5?
6 REPLIES 6
Message 2 of 7
Re: WiFi adapter gives poor performance with Home Hub 5
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
MCG65
Message 3 of 7
Split the networks
The answer is "yes" to both. As regards splitting the networks - the Home Hub 4 that this wifi adapter works well with has not had the networks split.
One thing I forgot to mention - the Speed Test shows an upload speed far higher than the download speed - about 6 Mbps. Does this mean anything?
v_glancy
Message 4 of 7
Buy a Home Hub 4 on eBay and throw the HH 5 in the bin, it's a piece of poorly conceived rubbish and more trouble than it's worth.
MCG65
Message 5 of 7
Seriously, that sounds like the easiest option since I have no wish to waste money buying a replacement wifi adapter that may or may not work.
Message 6 of 7
If you're going to spend money, get a proper router not another HH.
MCG65
Message 7 of 7
I know that the wifi adapter in question works 100% OK with a Home Hub 4 and they're dirt cheap on ebay, so why spend any more?
