mikeyaj
Message 1 of 59
WiFi and ethernet connections not fully working (ipv6 issue)
On Saturday morning (11th march 2017) i noticed that my Samsung galaxy s7 edge was no longer working on WiFi to my btsmart hub.
I could browse the internet with seemingly no trouble on the browser.
However Facebook, Google plus, Instagram ...... Any app would not work through WiFi.
Thought it was my phone but after reinstalling everything on my phone it's clear it's the by hub
Also noticed that i couldn't even join this forum through ethernet on my laptop as the capatcha code won't show
My connection is terrible.
After research to no avail i know its got something to do with ipv6 or whatever this is.
I have no idea have to get things back to the way they were before saturday.
I had to join this forum using mobile data on my phone due to the issue.
Please please please somebody explain my issue and help me fix it.
58 REPLIES 58
Message 2 of 59
Re: WiFi and ethernet connections not fully working (ipv6 issue)
@mikeyaj
Welcome to this user forum.
Have you tried a factory reset of the home hub?
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
mikeyaj
Message 3 of 59
of course
that was my first port of call
i've done all the "turn it of and on" , "factory reset" stuff
there must be an actual issue
is this ipv6 got anything to do with it?
Message 4 of 59
Please can you post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
mikeyaj
Message 5 of 59
@Keith_Beddoe
there is no noise between the announcements
here's the info from the link
Product name:
BT Hub 6A
Serial number:
+084319+NQ63500369
Firmware version:
SG4B10002244
Firmware updated:
18-Dec-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 33 Minutes 4 Seconds
Data rate:
20.00 kbps / 66.49 kbps
Maximum data rate:
19999 / 65066
Noise margin:
7.2 / 6.2
Line attenuation:
8
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
15 MB Uploaded / 214 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-7H9M
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-7H9M
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
88:A6:C6:28:EB:03
Software variant:
Boot loader:
7.33.1
Message 6 of 59
Cannot see anything wrong with those figures. I guess you must have done a factory reset a while back, as BT Wifi is showing inactive. Normally after a factory reset it shows as active, untill the next time the hub is contacted by BT, then the status is updated.
Could you please post the results from the http://speedtest.btwholesale.com/, including the further diagnostics, this must be done using an Ethernet cable.
See if anyone else on this user forum has any ideas
mikeyaj
Message 7 of 59
@Keith_Beddoe
download speed mbps = 62.11
upload speed mbps = 16.14
ping latency ms = 17.75
1. Best Effort Test: -provides background information.
 Download Speed
 62.11 Mbps
0 Mbps64.29 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 62.11 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-64.29 Mbps .
 Additional Information:
 IP Profile for your line is - 64.29 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 16.14 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 16.14Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
mikeyaj
Message 8 of 59
thanks for your help @Keith_Beddoe
but like i said in my original post this is linked to ipv6 issue. was hoping somebody could look into that
Message 9 of 59
Nothing wrong with that either, so you have a good connection right up to the BT core network.
There have been a few posts on this forum to do with BT DNS errors, which could explain missing images.
On your PC, would it be possible for you to temporarily change your network settings to use Google Public DNS instead of BTs DNS?
See if that resolves the issue with missing images.
Message 10 of 59
You could disable IPv6 on the smart hub, to see if it helps.
