mikeyaj
Message 11 of 59
Re: WiFi and ethernet connections not fully working (ipv6 issue)
how do i do these 2 options
i'll try dns first though. how do i do this
not been able to figure out how to disable ipv6 as there is no instructions anywhere here that make even the basic amount of sense.
Message 12 of 59
See https://developers.google.com/speed/public-dns/docs/using
Not sure about IPv6, the only option seems to be to disable ULA.
smf22
Recognised Expert
Message 13 of 59
You can't disable IPv6 completely on the Hub 6, you would have to do it on each client.
@mikeyaj. Can you share your findings as to why you think the problem is IPv6 related? The BT forum doesn't support IPv6 at this time so any connections to it can only be IPv4. As you had problems connecting here as well, it would make me question whether the problem is due to IPv6.
Regards
mikeyaj
Message 14 of 59
@smf22  mainly due to wifi not working on my phone
this isn't a pc issue, it's an all round wifi and ethernet issue
mikeyaj
Message 15 of 59
@Keith_Beddoe
none of those instructions actually tell me how to change anything or tally up with windows 10. windows 7 is an old os so those instructions don't work
Message 16 of 59
Have you turned off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Some devices have a problem with the Homehub dual band having the same SSid (name). You should try splitting them.
See link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
mikeyaj
Message 17 of 59
@gg30340
Those instructions for not tie up to my smarthub
I have split the 5ghz and 2ghz (the instructions you linked to are incorrect though)
Got rid of the smart setup which i have done before.
No effect on either my phone or pc
The pc is showing the capatcha images now
My main focus is being able to use apps on my phone through the WiFi though
mikeyaj
Message 18 of 59
Android apps no longer work through WIFI on the bt smart hub/ home hub 6
can't believe the suddent end of being able to use any apps on android through wifi on a bt home hub has not been mentioned here
running android 7.0 on an s7 edge. wifi works perfectly everywhere apart from all of a sudden it no long allows apps to use wifi at home.
wifi still works using my browser on android, but not any apps
any soultion?
Message 19 of 59
Re: Android apps no longer work through WIFI on the bt smart hub/ home hub 6
Sounds like a phone problem to me, if you can use a browser wifi is working ok.
mikeyaj
Message 20 of 59
had my phone sent for repair. it came back perfect. device has been tested on wifi and various networks and apps work fine
wifi works EVERYWHERE apart from when using apps through wifi at home with the home hub 6/smart hub
