Busyali
Message 1 of 7
WiFi connectivity
My son has a lenovo tablet that is refusing to connect to the bt WiFi, I thought it was a tablet issue as it has done this before but fixed post a hard reset. However I have just tried to connect the tablet via a hot spot on my phone and ir works perfectly, so is it a problem with the tablet or my WiFi. Incidentally the WiFi is hooked up perfectly to every other device in the house.
6 REPLIES 6
bratman91
Message 2 of 7
Re: WiFi connectivity
If you have other devices that are connected to your router via wifi, then I can’t see how there could be any problem with the router or wifi. Does the tablet settings allow the router SSID to be deleted or forgotten?  If so, I would suggest deleting it and then reselecting it so that you have to enter in the password.
Keith_Beddoe
Message 3 of 7
Busyali
Message 4 of 7
Thanks, I have tried removing it an readding it a couple of times. Interestingly it does work when I connect it to my phone as a hot spot. Think it must be a problem with the tablet. But I may try the channel switch as suggested. Just seems a lot of hassle just to get the one device to work when everything else is fine.
imjolly
Message 5 of 7
Providing you don't have a SH2 try splitting the 2.4/5ghz networks as some devices don't like them combined.
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
gg30340
Message 6 of 7
When you delete/forget the BT hub's wireless connection on the tablet, carry out a soft reset of the tablet before trying to re-connect to the hub.
If you are not sure how to do the soft reset try an Internet search for your model of tablet.
bratman91
Message 7 of 7
You have probably already tried this but restarting the router might help.
