Newbie
Message 1 of 6
WiFi frequency
My 5ghz frequency has a greater range than my 2.4ghz frequency. It's still working when I'm near the hub though, is it broken?
5 REPLIES 5
Message 2 of 6
Re: WiFi frequency
Welcome to this user forum.
It could be that the 2.4GHz wireless module, or its internal aerials, have gone faulty.
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn off smart setup.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Se if the wireless signal gets better. If not, then you have a faulty home hub.
Message 3 of 6
Re: WiFi frequency
you could also try splitting the 2.4/5ghz networks to see if that helps
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
Newbie
Message 4 of 6
Re: WiFi frequency
Appreciate the assistance, thank you, however unfortunately it was by splitting the frequency that I discovered this issue.
Newbie
Message 5 of 6
Re: WiFi frequency
Legend, thank you that's resolved it.
Message 6 of 6
Re: WiFi frequency
So the factory reset fixed it?
