Solitude
Newbie
Message 1 of 2
WiFi issues: Flashing orange and purple.
Bt smart hub has been changing from a standard blue to a flashing orange, flashing purple, steady orange and back to blue.
I've had similar issues before but never this regular, all cables seemed to be attached properly so I'm not sure what the issue is.
If anyone has any ideas or has a similar issue please respond.
Thanks in advance.
1 REPLY 1
Message 2 of 2
Re: WiFi issues: Flashing orange and purple.
with the hub changing colour as you describe it is really a connection issue and not a wifi issue
try quiet line test  dial 17070 option 2 should be silent and best with corded phone
are you connected to test socket with filter to eliminate any internal wiring as being a problem
