Message 1 of 4
WiFi mesh setup
I have fibre 900.
Speed is very good in the room where I have the main hub.
Its a fairly big house with thick walls.
the best I seem to get in other rooms is between 100 and 150
is that normal or should I expect more.
can anybody recommend a reasonable priced mesh setup that would improve it?
thanks
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: WiFi mesh setup
I would consider looking at the router first.
Message 3 of 4
Re: WiFi mesh setup
Ok.
Do you know if BT replace them for free?
Anonymous
Not applicable
Message 4 of 4
Re: WiFi mesh setup
Sadly no
But obviously there's nothing stopping you from getting your own router.
Several on here done this and swear by it.
I played safe and swapped my SH2 for the EE router
My wifi speed on 500mbps went from 200mbps to 500mbps.
