aaronf
Message 1 of 7
WiFi slow
Hi There,
I am having issues where my speed test is sticking to like 20mbps down when I'm supposed to be getting 65-80mbps. Bt have fitted a new socket said there wasnt a problem and installed a new router and said the house gets 62 through the line. A few months ago I would get 54mbps no problem and now I struggle to get 40.
6 REPLIES 6
albertj
Recognised Expert
Message 2 of 7
Re: WiFi slow
Have you tried running the test via Ethenet and using the BT Speed Test tool?
http://speedtest.btwholesale.com/
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
aaronf
Message 3 of 7
Re: WiFi slow
Yes I've tried that now and that says 40 but what I can't understand is I was getting 50+mbps instantly
albertj
Recognised Expert
Message 4 of 7
Re: WiFi slow
And this was taken over Ethernet?
Go to this link: https://www.dslchecker.bt.com/ post results but remove phone number and cabinet.
imjolly
Message 5 of 7
Re: WiFi sclow
Post your connection stats from your asus router
aaronf
Message 6 of 7
Re: WiFi slow
I have done this before but I was unsure to how reliable the results are as no one from BT has recommended this before..
aaronf
Message 7 of 7
Re: WiFi sclow
I no longer have that asus router. i am planning on getting a Draytek 2862 and a Ubiquiti Networks system
