Vincent98
Message 1 of 2
WiFi speed on iPhone is slower
Ethernet: 38mbps
WiFi: 37mbps
iPhone: 12mbps
Does anybody have the same problem where the speed on a iPhone is incredibly slower? I've seen a few posts that say I can try changing the wireless channel but if so, which channel would be the best?
Thank you.
1 REPLY 1
Message 2 of 2
Re: WiFi speed on iPhone is slower
If you want to change the wireless channel you should download and use inSSider. This will show you the channels that are being used and you should select the least congested channel.
http://www.metageek.net/products/inssider/
Try "forgetting" the connection on your iphone and then re connect. It may improve the speed.
