RoloTheRed
Message 1 of 5
WiFi very poor connection to ring camera
All I have broadband 2 with smart hub which works great apart from poor connection to ring cameras attached outside the house.
do the disc extension things work?
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: WiFi very poor connection to ring camera
@RoloTheRed
Which BT Home hub are you using at the moment, is it the Smart Hub 2?
There are other cheaper alternatives you may wish to try, especially if there is a mains socket inside, near the outside camera.
https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
Anonymous
Not applicable
Message 3 of 5
I've found the black discs to be excellent but they are associated with a regular monthly cost ad-infinitum whereas the solution suggested by @Keith_Beddoe  incurs a one off cost only
RoloTheRed
Message 4 of 5
Hi, it's only the smart hub 1
Keith_Beddoe
Message 5 of 5
Then the hotspot kit is your best option. Just plug the remote unit in a mains socket nearest to the camera. If you cannot easily change the wireless settings on the camera, then you will need to change the hotspot settings to match your home hub.
If you can change the settings on the camera, then change them to match the hotspot wireless network, as that way you will always make sure the camera connects to the hotspot, and not the home hub. That is the best method.
