Message 1 of 3
Wifi Device with 10 ip rather than 192 Address
How would I connect and be able to ping a 10.10. ...... wifi device via my BT Hub that has a gateway address of 192.168.1.254?
2 REPLIES 2
Message 2 of 3
Re: Wifi Device with 10 ip rather than 192 Address
With IP starting 10 suggests a connection to the BTWIFI network from your BT hub. This broadcast from hub but is not a problem and connection do not have access to your home network .  This can be turned of in MYBT but you lose access to BTWIFI when you are away from home
Message 3 of 3
If you have a 10.10 device that is connected to your WiFi, the changing the ip address on a PC or pad etc. that is connected to your network from 192... to a static 10.10.x.x address would allow you ping that device you want to.
All 10.x.y.z addresses are private as such you will not be able to ping them over the Internet.
A little more information about what the objective is might get you a more detailed answer.
