Cloggy1641
Message 1 of 5
Wifi Disc pairing problem
Initially when I received the 'Smart Hub 2' and 'Wi-Fi Disk' everything set up with ease. However the 'Wi-Fi Disk' disconnected from the network at some point (Nothing has changed from the initial set up, nothing moved, added or changed) and now will not reconnect. I have tried resetting the Disk and starting afresh by connecting directly to the hub using an ethernet cable and the disk responds by turning on a solid blue light after a couple of minutes however when I disconnect the ethernet cable the light turns red and flashes no matter how long I wait.  I have gone through the set up procedure multiple times with the same end results.  Help Please
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Wifi Disc pairing problem
@Cloggy1641
You do not connect it to the home hub.
You should have received an install guide with your new smart hub 2 and black disc.
Instructions are in there, including detail for downloading the correct MyBT app, and how to install your disc (it doesn't need to be connected to the hub).
Perhaps you are using the wrong app?.
VeteranISPUser
Recognised Expert
Message 3 of 5
Hi @Cloggy1641   Have you tried factory resetting both SH2 and Disc using the reset hole in the back of both. Then setting up the whole system as new. Remember to apply any changes like switching off smart setup.
Anonymous
Not applicable
Message 4 of 5
I haven't read it all but  this thread seems to suggest that a factory reset of the SH2 is required
Cloggy1641
Message 5 of 5
Hi, yes have tried a factory reset on both. Since posting the problem, I have spoken to BT, a very helpful chap feels that the disc is faulty and they are sending a replacemet.  Keeping fingers crossed.
