Bwickens84
Newbie
Message 1 of 2
Wifi connection for iPhones
My laptop connects fine to my hub4 my xbox360 connects fine but when using most apps on my iPhone it's very poor at best any ideas please?
1 REPLY 1
Message 2 of 2
Re: Wifi connection for iPhones
If you haven't already done so, switch off "Smart set Up" on the homehub. It can cause problems.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
If that doesn't help download a Wifi Analyser app for you smartphone or use the free version of inSSider from forum member Keith Beddoe's website here
http://forumhelp.dyndns.info/software/insidder.zip
It will show you the wireless channels and which one your Homehub is on. You want to find the channel with the least congestion, ie. least number of users. Once you have that you need to change your homehub onto that channel.
See link how to change channel on homehub
http://bt.custhelp.com/app/answers/detail/a_id/14094
