Message 1 of 4
Wifi connections
We have BT Halo 3 with a HomeHub 2 downstairs, and 1 extra disc upstairs. According to MyBT app both devices have excellent signal. However, the disc can have 8 devices connected, 7 of which are used downstairs, while the HomeHub only has 1 device connected, the doorbell. Can anyone explain why this happens? Is it to do with banding?
3 REPLIES 3
Message 2 of 4
Re: Wifi connections
It's devices that choose which source to connect to, not the hub or discs.
The 5Ghz band is faster but has a shorter range than the 2.4Ghz band.
Message 3 of 4
Do the hub and the disc have dual bands? The majority of our devices are in the same room as the hub, whereas the disc is 5x further away.
Message 4 of 4
Yes, they are both dual band.
