Shaw42
Newbie
Message 1 of 2
Wifi disk
I have bt complete with one disk mainly for online gaming. My question is. If I go wired from disk to xbox will it be a better connection than going wireless from disk to xbox.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Wifi disk
Hi @Shaw42  welcome to the forum and thanks for posting about your complete wifi set up. Check out this earlier thread which may help answer this for you.
cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
