Dboland277
Newbie
Message 1 of 3
Wifi not working on Not so smart hub
Hi I have the new smart hub which was working fine untill last night. For some reason any device which is connected via the wireless will not be able to use the internet. I have tryed setting the setting manually and even performed a factory reset on the router. The internet works fine useing my ethernet cabel and over my extender with the powerline kit and nothing has changed in my setup which has been working fine untill now. The hub is only 2 months old so if this can't be fixed can someone help me return this to get one which works, Thanks.
2 REPLIES 2
kinetic747
Message 2 of 3
Re: Wifi not working on Not so smart hub
Dboland277
Newbie
Message 3 of 3
Yea I just found that page, Thanks thoe. Mebe BT will get and sort something out about this soon.
