Pardigan
Message 1 of 8
Wifi speeds are half of ethernet speeds
Hi guys.
I've been with BT since December and noticed that intitially we were getting the full 300+ fibre speeds on both ethernet and wifi.
Since then, the wifi speeds have dropped to  around 80Mbps. I've changed channels on the router to improve this and it's got to over 100Mbps, but this still doesn't seem right.
The router is away from other electrical equipment, there has been no changes in what's connected (several Amazon Echo's and normally 2 iPhones), so is there something I'm missing to improve this? These speeds are me directly in front of the router.
Thanks in advance
James
Tags (3)
7 REPLIES 7
Message 2 of 8
Re: Wifi speeds are half of ethernet speeds
Welcome to this user forum.
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
You may be suffering from wireless interference from another nearby wireless network on the same or adjacent channel.
Pardigan
Message 3 of 8
Thanks for the response Keith.
I've turned smart setup off already, but will give it a factory reset later to see if this helps. I don't seem to be able to rename the SSIDs on my hub which is a bit of a pain.
Message 4 of 8
you should be able to change the SSID ( I changed mine) but some characters are not permitted and no spaces
Pardigan
Message 5 of 8
I'm unable to change the SSID on my Smart hub 2 sadly.
TheSeasider
Message 6 of 8
No body can .. its a Right PITA !!!!
Message 7 of 8
You can change the SSID, but they will always be the same for both bands.
http://bt.custhelp.com/app/answers/detail/a_id/14110/~/how-do-i-change-the-wi-fi-password-on-my-bt-h...
Changing the wireless password on your BT Hub
Use  change the network name.
TheSeasider
Message 8 of 8
Yeah I meant change them to DIFFERENT names Keith ..
