Message 1 of 6
Wifi to an outside building
I have full fibre broadband with Smart hub 2 and 2 WiFi disks which give signal to the top of my long garden but doesen't penetrate a wooden (solidly built 6 inch insulated walls with metal roof) outbuilding, signal outside the door but none inside. I thought that a weatherproof  extender mounted on the outside of the building (near a small window) would probably be a solution. There's too many obstacles to run a solid cable so got to work with wifi signal. Any suggestions of something suitable and compatible to existing system?  I have seen various makes and models advertised but none give a comprehensive description of does it need external power or how it connects inside the building and I can't afford to buy something that doesn't work.
5 REPLIES 5
Message 2 of 6
Re: Wifi to an outside building
I would suspect the metal roof is reflecting/absorbing most of the signal.
When you say insulated walls, that's not metal foil is it?  If so, same problem.
Edit:  Thought occurs...if that outbuilding is connected to the house electricity supply, then powerline adapters may be the answer.  Lot depends on how it's wired though.
Message 3 of 6
No it's not metal foil insulation  it's mainly fibeglass, powerline adapters won't work  as the router is on a different circuit, I've still got some from my original installation before full fibre upgrade etc and they were hit and miss extending the wifi.
Message 4 of 6
In that case I'd look up "Point to Point" wireless.
I've no experience of it outside of industrial use, so I've no idea what's available on the domestic market.  The industrial stuff would be a bit expensive but I would not be surprised if there's something like a home version today.
Message 5 of 6
When you say the electric is on a different circuit do you mean it is fed from a different consumer unit (fuse box). If it is all going through the same consumer unit powerline adapters even if on a different ring or radial circuit should still work ok.
If you can the best option is to run an Ethernet cable from the Smarthub to the outhouse then connect it to a wireless access point (WAP) in the outhouse. This will give you both an Ethernet connection and a wireless connection.
Message 6 of 6
Hi
If you mean that you already have two black WiFi discs provided by BT as part of your existing package, then you can have more discs for no extra charge.
You could try cloning what I have done and have an extender on the outside of the building with a Cat 5 cable and the power run through the wall. I have installed the extender in a waterproof box on the outside and it works really well.
You could order the disc and just see if it works perched outside on the floor for no cost....  The waterproof box cost me ~£15 online.
Tim
