JamieDev
Message 1 of 12
Windows Vista compatibility with BT Infinity
I was upgraded to BT Infinity yesterday and at the point of upgrade my sony laptop (Windows Vista Ultimate) could find the new home hub but only with local access.  I have another laptop, ipad, iphone, etc that are connecting fine.  Could the wireless driver need to be upgraded?
11 REPLIES 11
Message 2 of 12
Re: Windows Vista compatibility with BT Infinity
JamieDev
Message 3 of 12
The help suggests I might need to upgrade my wireless adapter.  Is this normal for BT Infinity?  Can I apply the necessary upgrade via an online download or do I need to buy a new adapter?
Message 4 of 12
If your wireless adapter does not support WPA encryption, then a driver update normally fixes it. I would be surprised if its that old.
Message 5 of 12
Funnily enough I've just had to replace the wireless adaptors on my desktop after a few years; their integrity had slipped.
Check the configuration of the kit on the device. I'd then try a solid ethernet connection and see if the issue is resolved.
If you obtain a connection by ethernet, IMHO I'd get some software to replace the adaptors. £20ish should do it; check the compatability of the software you might buy with your device o/s etc.
AQ.
"Welcome to Royston Vasey - You'll never leave."
JamieDev
Message 6 of 12
Thanks for the suggestions.  My wireless adapter is "g" rather than "n" that BT recommends.  Should I buy an upgrade?
Message 7 of 12
That should not affect the ability to connect. If you do not have any wireless "n" devices, then set tour home hub to b/g only.
JamieDev
Message 8 of 12
Thanks again for the suggestions.  I bought a USB wireless adapter from Maplin yesterdat for £25 which has worked fine.  Much easier than the BT / PC World Know How options, restoring my laptop for the sixth time or replacing all sorts of hardware!
Guru
Message 9 of 12
Personally, i would go back to the Operating system as an issue, Windows Vista is not the greatest and i've had so many issues with it generally.
When i upgraded to Windows 7, connection dropouts etc seemed to stop.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 10 of 12
Thanks for the update.
Its interesting that there is a user with the same problem with a HH3 on the thread below. I have referred them to this thread.
http://community.bt.com/t5/BB-Speed-Connection-Issues/Broadband-Going-Down-On-Three-Out-Four-Applian...
