Message 1 of 3
Wired internet in second bedroom
I have just had fibre internet installed downstairs.
I have a wired PC upstairs in our second bedroom. Is it possible to get a wired internet upstairs?
2 REPLIES 2
Message 2 of 3
Re: Wired internet in second bedroom
You can either run an Ethernet cable from the hub upstairs to your PC or you could use powerline adapters to connect.
Message 3 of 3
Either use powerline adapters or run an ethernet cable upstairs.
