Message 1 of 10
Wireless Dropping out using WPA & WPA2 Wireless Security
Home Hub 3.0 Type A with mixed clients including Android, iPhones, iPads, Macs and PCs
Software version 4.7.5.1.83.8.94.1.52 (Type A) |
WiFi: b/g/n using both Default SSID & Renamed SSID with WPA & WPA2 Wireless security
Symptoms: Ethernet Broadband access stays operational while the WiFi connection stopped working after an apparently random short period of time. Normally less than 20 Minutes.
After much frustration, rebooting and factory resetting, I switched to b/g with WPA wireless security and the Hub WiFi stayed operational for two days, and now I've been running for an hour with no dropouts using b/g/n and WPA wireless security.
Yes I know that WPA is less secure than WPA2, but it's way better than WEP, and a stable WiFi hotspot that doesn't involve continuously rebooting the router with the resulting downgrade in speed (Thanks for DLM BT!) is far more acceptable. (The Holiday Cottage is on Orkney and is not in serious risk of WiFi Hackers!!)
Sadly I am at this Holiday Cottage for less time than the Dynamic Line Management will take to get the speed back up by itself. I wonder if I should try and persuade a friendly BT Tech to manually reset the DLM speed.
The Moral of the Story:
If you are having WiFi repeatedly dropping out then consider
lowering the Wireless Security from WPA & WPA2 to WPA.
9 REPLIES 9
Message 2 of 10
Re: Wireless Dropping out using WPA & WPA2 Wireless Security
if factory reset didn't solve the wifi problem then as long as in fixed term contract and not rolling monthly then report faulty hub to CS and as for free replacement
I would doubt that CS can reset the DLM and as long as not banded profile the DLM should restore your previous conenction speed provided line is stable
Message 3 of 10
or spend £30 on a decent third party router.
Message 4 of 10
I have at home, this is a rental holiday cottage. Not mine!
Message 5 of 10
Update: The Wireless also dropped out using b/g/n with WPA Only
I have switched back to b/g with WPA Only it stayed up over night!
When will BT fix this?  Anyone?
Message 6 of 10
When the owner of the property reports the fault.
Message 7 of 10
Surely Sarcasm doesn’t become a Sage!?
Message 8 of 10
there is nothing BT will or can do without contact from the BT account owner   as you are only renting a holiday cottage you need to contact the owner of the cottage who presumably is the BT customer
Message 9 of 10
Not sarcasm, fact. How else do you think it will get fixed?
Message 10 of 10
If the drop outs are fixed by changing the wireless security it would appear to be a wireless issue and not a broadband/line issue.
It would need to be determined if the router was faulty or if there was another reason such as a wireless device causing the drop outs. If it was a faulty router and the owner was still in contract the router would be replaced free of charge by BT.
If the owner is out of contract he/she would need to replace the router at their own cost.
In any event BT will and can do absolutely nothing until they are advised of a fault by the owner/account holder.
With that in mind I fail to see where sarcasm comes into any of the posts.
