fademidun
Message 1 of 3
Wireless Network Name
Can I setup my own Wireless Network Name/SSID as to using default BT Name?. What is the IP to logon to the Hub
2 REPLIES 2
Message 2 of 3
Re: Wireless Network Name
To enter the hub manager - http://bthomehub.home/
or http://192.168.1.254
Click 'A-Z', then 'W', then 'Wireless connections, enable or disable'
Enter your admin password
In the Wireless network name (SSID) change the name to what you want.
Click Apply
If you ever have to do a factory reset of the Homehub it will obviously revert back to the name etc on the label.
Distinguished Guru
Distinguished Guru
Message 3 of 3
Enter 192.168.1.254 in your browser Advanced Settings > Password > Wireless > change it > Apply. That's HH4, other versions are similar.
