Chris-T25
Message 1 of 23
Wireless disconnecting and refusing to connect some devices after a few days
I have a problem with my BT router (Smart Hub) where some wireless devices get disconnected and wont reconnect without a router restart.  I've tried pinning the problem down to specific wireless network (5 or 2.4ghz), distance from the router, wifi channels, DHCP lease times,  but the problem still persists.  Wired devices are fine.   I've also reset the router to defaults.
One device that is affected is my mobile.  When trying to connect the wifi on the mobile says Denied.  At the moment I'm having to restart my router every couple of days or so.
Any ideas would be great.
Chris.
Tags (3)
22 REPLIES 22
gg30340
Message 2 of 23
Re: Wireless disconnecting and refusing to connect some devices after a few days
Try a factory reset of the Smarthub by pressing a pin into the recess button on the rear for about 20 seconds. This can often sort out problems.
After you have done that make sure you turn off "smart setup" on the Smarthub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
imjolly
Message 3 of 23
did you turn off smart setup as that can cause problems
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
if you have SH1 you can split the networks  but if SH2 you can't
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
with mobile did you forget the network so it is deleted from phone then try and connect again
Chris-T25
Message 4 of 23
Thank you. I'll try that tonight. I've done a factory reset via the web interface but not the button.
Chris-T25
Message 5 of 23
Hi, I did turn off smart setup. I did see the option to split the networks so think I will try that.
Yes, I forgot the network on my mobile and tried reconnecting without luck until I restarted the router.
Thanks for the help. I'll try splitting the networks later.
licquorice
Message 6 of 23
There is no factory reset via the web interface, that is just a restart.
Chris-T25
Message 7 of 23
I used the Factory Reset here.I used the Factory Reset here.
That's the Factory Reset I used.  It did reset the passwords to the defaults.  Maybe I'm mistaken though.  I'll be trying the button on the back later
licquorice
Message 8 of 23
So there is, I've only noticed this one before.
Still worth trying the button though.
Message 9 of 23
@licquorice ,
It's a while since I did a factory reset on a HH where somehow the Reset Button refused to respond, and I had to connect to the hub via ethernet/usb.
Then the option to reset from the Hub Manager menu appears. It's a rare case probably not the case here though.
Chris-T25
Message 10 of 23
Hi, Well I reset the router via the button on the back and turned off Smart Setup as well as seperate the Wifi (I only have 1 device that is 5Ghz) and after about 1 day the same problem happened again 😞
Restarting the router fixes the issue but I don't want to do that every day.
Do you think I need to get a replacement router or in some way contact BT? I've had it over 1 year without issues until now and I've not changed it config for well over 6 months
