9kenny5
Message 1 of 5
Wireless not working, wired working
I have the 3.0 home hub and all the lights are blue. I can access the internet while connected using an ethernet cable, but cannot connect wirelessly with anything. And even when it is working, it's really slow using multiple computers but that's another issue for another time.
4 REPLIES 4
Message 2 of 5
Re: Wireless not working, wired working
have you tried changing wireless channels
9kenny5
Message 3 of 5
how can do i do that?
Message 4 of 5
hi type 192.168.1.254 into your browser address bar the once past the pass word page go to settings select advanced then click on continue to advanced settings then click on wireless then go down to channel selection then click on the pull down menu select another channel
then click on apply select a channel as far away as you can from the one you are on
Message 5 of 5
Please look at "wireless connection problems" on my website below for assistance.
