Message 1 of 4
XR500 Setup with HG612
Hi can anybody help me with this I've bought a Netgear XR500 gaming router and can't get it to connect to the internet.I have a HG612 modem which when used with my previous router a Netgear DGND3700V2 it worked flawlessly.Do I need to change any settings?Thanks
3 REPLIES 3
Message 2 of 4
Re: XR500 Setup with HG612
Not on the HG612. The new router settings should be identical to those on the old one.
Message 3 of 4
What do I need to change?
Message 4 of 4
As I just said, nothing on the HG612 and just make sure you have made the same settings on the new router as on the old. Nothing needs to change.
