Darkson
Message 1 of 3
Xbox 360 won't connect to Smart Hub 2
Hello all,
Having an issue - I've recently switched from a Home Hub to a Smart Hub 2, and I can no longer get the Xbox 360 (note, NOT an Xbox One) to connect to the internet.
I've read a few of the many replies and fixes here, but unfortunately they all seem to presuppose more technical know-how than I possess!
Can anyone give me a basic step-by-step walkthrough on how I can fix this?
1. Has to be wireless - I can't physically get the hub and/or Xbox together.
2. I can access the Hub manager, which can see the Xbox, and I can access the Xbox's settings, which can see the home network.
P.S. Yes, I know the 360 is years old, but I'm happy with it!
P.P.S. If I reset the Xbox network settings to 'Factory default' it will successfully connect to the network for a day or two, but then will fail - obviously resetting every few days isn't a long-term solution!
Tags (3)
2 REPLIES 2
youlethal
Message 2 of 3
Re: Xbox 360 won't connect to Smart Hub 2
Hi There!
You can try a few things to fix this with the BT smart hub settings. First turn off smart mode on the hub.
Next go to wireless settings and turn wireless mode to mode 2 on the BT router and set 5hz to channel 48
If mode 2 doesn't work try mode 3. One of them should work
Darkson
Message 3 of 3
Firstly, many thanks for the reply.
" First turn off smart mode on the hub." - ok, can't see any option to do this?
Rest I can see, and will have a try when I next get a couple of days off, in case I screw anything up!
