Message 1 of 4
Xbox Fortnite performance lag
My son has an Xbox One, and we have BT home hub. We generally have around 20Mb of bandwidth, which I though should be sufficient for his gaming, particularly when nobody else in the house is really using the internet, However, he complains that he has 300-1000 ping on Fornite, which makes it very laggy. When I run a speed test all seems fine, and there is no major delay. I there anything I can do to the router configuration to make it perform better?
3 REPLIES 3
Message 2 of 4
Re: Xbox Fortnite performance lag
ok just make sure you use eu servers in his settings if you play with usa servers you will have a lag that big
Message 3 of 4
just saying usa is around 300+ in ping which is unplayable making a change in settings in fortnite from usa to eu server can make a dif you can't change anything in router configuration to make it perform better if its a bt hub ask your son to change the settings to eu will put it around lower then he is getting now
Message 4 of 4
Thanks for the reply. He tells me he is definitely using euro servers.
