Goetzsta
Message 1 of 7
Xbox One /Guitar Hero Live / Activision
Hi, I've finally got my internet up and running after a month of them not turning it on and the first thing I want to do is play my new game online...
This is proving very difficult as it will not let me connect to the servers, I've tried portforwaring loads of ports suggested on other posts, but no luck.
Has anyone got any suggestions that will help me be able to play online.
My experience with BT so far has been awful and would really just love to sit down, chill out and play some games.
Cheers ,
Goetz
6 REPLIES 6
Goetzsta
Message 2 of 7
Re: Xbox One /Guitar Hero Live / Activision
I've tried sticking my XBOne in DMZ and turning off upnp... Still nothing, I've ran out of ideas apart from get a decent router
MarkG33
Message 3 of 7
Hi @Goetzsta.
A few questions just so I can get some things right.
Are you on ADSL or fibre?
What home hub are you using e.g. - Home hub 3/4/5 etc.
How are you connecting, wires or wireless?
Have you tried a connection test on the Xbox One?
Can you even connect to XBL?
Basic questions as I have an Xbox One and Guitar Hero Live and do not have any issues. My set up is a HH5A, hard wired, static IP and DMZ (When not using my PS4.)
*This is my signature...it's a bit boring*
Goetzsta
Message 4 of 7
Hi @MarkG33 , thanks for the reply
I'm on fibre, with a homehub 5. Wired connection to my Xbox.
Yes I can connect to Xbox live, I now have open NAT after setting up my Xbox one with a Static IP and forwarding ports 3074 & 3075
I'm unsure what you mean by a connection test on my Xbox one?
Any opinions and suggestions would be greatly appreciated
MarkG33
Message 5 of 7
Glad you've got your nat open now so that's good!
A connection test as in what the ps4 has to check speeds, nat type etc. I find redoing the connection helps from time to time, refreshes the connection between the Xbox One and Home Hub.
Goetzsta
Message 6 of 7
My NAT type is open, but I still cannot connect to the guitar hero servers to play online 😞
MarkG33
Message 7 of 7
Perhaps it may be their servers then. Does other games work ok? I haven't tried GH since I posted last time.
