allington73
Message 1 of 3
Xbox One S Mic muted - home hub issue ?
I have constant mic mute symbol on my xbox one s.  I have confirmed head phones work and after much searching on internet I suspect the home hub may be the issue.
I have tried multiple xbox "fixes" without any luck
So I now suspect that either the NAT settings or UPnP may be at fault.  I currently have a moderate NAT which I have read should be ok but UPnP unavailable.  UPnP in home hub menu states that it is on
Any help appreciated !
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Xbox One S Mic muted - home hub issue ?
allington73
Message 3 of 3
Hadn't tried this but just turned to off but no joy.
Thanks for suggestion
