Nobbzii
Newbie
Message 1 of 7
Xbox One nat settings
Xbox One has moderate nat settings, got honehub 5, any idea how to fix? Help would be appreciated!
6 REPLIES 6
lowei
Expert
Message 2 of 7
Re: Xbox One nat settings
Microsoft are trying to fix this and its not just a BT problem.
Try This link to help you at the moment.
ben_leveridge
Message 3 of 7
Can you setup a DMZ on the HH5? on my netgear I found the best way to stop lag was to use a wired connection and use the DMZ
Nobbzii
Newbie
Message 4 of 7
Thanks for the reply, any idea of a time on the fix? It's so bad I can't get into a game!
lowei
Expert
Message 5 of 7
Fix time not known, have you tried this http://bt.custhelp.com/app/answers/detail/a_id/46548
Malacath
Expert
Message 6 of 7
There are reports on xbox forums that going into the settings app, changing the power settings to energy saving mode,switching off console, rebooting router then switching console back on has fixed nat settings for some people.
also if its only call of duty giving you a moderate nat then you should forward port 3075 to the xbox one
Nobbzii
Newbie
Message 7 of 7
Thanks for the help guys, i've fixed it, I opened the ports nesasarry for Xbox live and changed the Firewall settings and the NATs open now
