Max900
Message 1 of 1
Xbox Series X Download Speed Fix
FYI Some BT customers are suffering from capped downloads from their Xbox Series X.
The solution is to turn off Smart Setup on the homehub! No idea why it works or if it's a BT or Microsoft issue but if you have a fast line and only get 10Mbps down, this will likely solve the problem.
Hope this helps other. The solution is from Microsoft forums but I felt like it should be shared here too.
