Message 1 of 3
Xbox direct connection to ont box.
Hi
Is it possible to connect a gaming console to the ont box?
2 REPLIES 2
Message 2 of 3
Re: Xbox direct connection to ont box.
If it supports PPPoE, then yes.
Message 3 of 3
Having a look in the network settings on the series s i can't find any option to enter pppoe username and password so unfortunately it looks like it don't support it.  Hopefully in the future Microsoft will add this option. Thanks for your help, appreciated.
