Saibhy
Message 1 of 6
Your Ping To EA
Hi guys,
I am really fed up with gaming on bt broadband, i have high pings to ea.com, i can see alot of other people have problems with fifa on here aswell.
I am already speaking to a mod to get this sorted but just for interest i want you guys to please post me your pings to WWW.ea.com
please post your results so i can see if i am the only one with those high pings.
thanks
Instructions: open Cmd then type, Ping www.ea.com
5 REPLIES 5
pauluea
Newbie
Message 2 of 6
Re: Your Ping To EA
Mine is 126ms
Semmy
Message 3 of 6
Re: Your Ping To EA
Just done a quick trace route on this and I am getting 142ms, however this is not a BT issue......
The ping on BT's network is in the region of 15-25ms... Pretty decent.
The traceroute shows www.ea.com as hosted in the USA, therefore a ping of 140+ is not too shabby. Is there a UK hosted EA site you could use instead, or lobby EA to set up UK based servers.
Semmy
Message 4 of 6
Re: Your Ping To EA
Tracing route to www.ea.com [98.129.150.221] over a maximum of 30 hops:
1    <1 ms    <1 ms    <1 ms  BTHomeHub.home [192.168.1.254]
2    10 ms    11 ms    10 ms  ***.***.***.***
3    11 ms    12 ms    11 ms  ***.***.***.***
4    13 ms    12 ms    13 ms  ***.***.***.***
5    15 ms    12 ms    13 ms  ***.***.***.***
6    14 ms    13 ms    13 ms  ***.***.***.***
7    18 ms    13 ms    12 ms  acc1-10GigE-3-2-0.sf.21cn-ipp.bt.net [109.159.25 1.89]
8    25 ms    23 ms    23 ms  core1-te-0-13-0-13.ealing.ukcore.bt.net [109.159 .251.167]
9    51 ms    20 ms    21 ms  peer1-xe1-0-0.redbus.ukcore.bt.net [62.6.200.77]
10    20 ms    20 ms    20 ms  ge-2-1-0.mpr1.lhr2.uk.above.net [195.66.224.76]
11    19 ms    19 ms    19 ms  ge-2-1-0.mpr1.lhr2.uk.above.net [64.125.28.141]
12    93 ms    92 ms    93 ms  xe-5-2-0.cr1.dca2.us.above.net [64.125.26.21]
13   126 ms   125 ms   125 ms  xe-2-2-0.cr1.iah1.us.above.net [64.125.29.37]
14   130 ms   126 ms   126 ms  xe-2-1-0.cr1.dfw2.us.above.net [64.125.30.58]
15   124 ms   125 ms   124 ms  xe-8-2-0.er1.dfw2.us.above.net [64.125.30.81]
16   130 ms   131 ms   129 ms  main1.above.net [209.133.126.42]
17   143 ms   143 ms   142 ms  corea.dfw1.rackspace.net [74.205.108.38]
18   144 ms   143 ms   143 ms  core7.dfw1.rackspace.net [74.205.108.15]
19   142 ms   143 ms   143 ms  aggr502a-2-core7.dfw1.rackspace.net [98.129.84.2 3]
20   142 ms   140 ms   141 ms  98.129.150.221
Trace complete.
BT's network ends at hop 9 where the ping is a very good 21ms
As you can see at hop 12/13 the route goes over to the US, so this is definitely an EA issue.
mohammedmumtaz
Message 5 of 6
Re: Your Ping To EA
I've contacted EA many times and they put the blame on BT. I replied a few days ago and told them enough was enough and I am contacting Watchdog and anyone else who will listen because their servers are absolutely horrendous.
Hangerhead
Message 6 of 6
Re: Your Ping To EA
Ping statistics for 23.35.219.9:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 112ms, Maximum = 135ms, Average = 123ms
