Message 1 of 3
asus tablet wont connect to bthub6-92cf
yesterday installed bthub 6.  Smart tv ok  2 laptops connected ok 2 smart phones connected ok 1 tablet connected ok. But other tablet same make model will not connect there is a message that appears after attempting to connect that reads [avoided poor internet connection] signal strength good link speed 65mbps any ideas please. just a quick point everything performed perfectly prior to fitting new router including the tablet that now wont connect using bt homehub 3.                                 Thanks hopeing to hear something soon
2 REPLIES 2
Message 2 of 3
Re: asus tablet wont connect to bthub6-92cf
Welcome to this user forum.
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
Message 3 of 3
With hh6 you don't have to rename the SSID. The hub will automatically add a 5 to the 5ghz band
