helzapoppin
Message 1 of 9
bt home page
just got a new dell laptop windows 10. in exploerer 11 can you make bt your home page, becuase i got this on the bt home page your current operating system is not supported.
8 REPLIES 8
Message 2 of 9
Re: bt home page
Why would you want to make BT your home page?
Liam_
Expert
Message 3 of 9
Re: bt home page
Hi,
IE is pretty naff.  Try Firefox, Waterfox or something else.   Edge is even worse.
Liam_
Expert
Message 4 of 9
Re: bt home page
Not sure what you mean 'current operating system is not supported.'
I dual boot Win 7 & 10.  Last post was 7 this is while in Win10 and BT homepage loads fine in Waterfox.
Distinguished Guru
Message 5 of 9
Re: bt home page
I guess you are clicking on the "Make BT.com my homepage" link on the main bt.com web site.  That then takes you to another web page view-source:https://www.bt.com/static/includes/account/portal/?TARGET=$SM$http%3A%2F%2Fhome.bt.com
Looking at the source of that page, it attempts to work out what web browser you are using and presents the appropriate instructions.  However, there's no entry for "Edge", so it just presents a generic "not supported" message.
Ignore all that.  If you want to make bt.com your home page, then just tell your web browser to make it your home page.  I don't know how to do that in Edge, since I'm a Luddite who refused to upgrade from Win7.  But it's been an option somewhere in every web browser i have used for many years.
Liam_
Expert
Message 6 of 9
Re: bt home page
If you really want bt.com as the home page then paste it in, once on the page, via tools set as home page.
Let's assume the menu bar is missing.
Right-click the title-bar, the top-most strip across Internet Explorer, to see the pop-up menu.
Choose Menu Bar
Then try Tools/Options/ & probably the General, tab, button whatever.  Then 'use current page'  rather self explanatory.
Can't be any more exact as I refuse to use IE.  Think the last time I used it was Windows 95, IE3 on and only long enough to find and download Netscape.  Then Phoenix when it came out, forward to present and 64bit Waterfox.
helzapoppin
Message 7 of 9
Re: bt home page
i was clicking on the link has you said ectophile, i have got another web page nsandi when i log into it using exploorer 11 it
says your browser is not supported. so i thought it might work logging on through( bt home page google) but i still get your
browser is not supported. if i use edge browser to log on to nsand i dont the message.then kaspersky safe money does not
work with the edge browser. thats why i was trying bt home page.
i am using bing has my home page in explorer 11, tried google thats works with nsandi ok but i dont like all the **bleep** what comes with google. thanks for all the replys
Message 8 of 9
Re: bt home page
Try using Opera as a browser, it seems to work with sites that are picky about browsers.
helzapoppin
Message 9 of 9
Re: bt home page
ok i will give that a try thanks
